跳转到主内容
Toshiba Satellite E45-B4200 Speakers Replacement
你所需要的
  1. Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 步骤 1 中的图像 3,3
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: 步骤 2 中的图像 1,2 Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: 步骤 2 中的图像 2,2
    • To remove the speakers from the motherboard, pull the speaker cables away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  3. Toshiba Satellite E45-B4200 Speakers Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite E45-B4200 Speakers Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite E45-B4200 Speakers Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #0 screwdriver, unscrew the two screws from each speaker, that hold them in place.
    • You don't need to remove the screws, just unscrew them to the point that you're able to remove them from the device.
  4. Toshiba Satellite E45-B4200 Speakers Replacement: 步骤 4 中的图像 1,1
    • Gently remove the speakers from the laptop. Make sure to disconnect the speaker wires from the frame prior to lifting the speakers out.
结论
Raymond Makynen
于03/20/23注册
289 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 151
