跳转到主内容
Toshiba Satellite E45-B4200 RAM Replacement
你所需要的
  1. Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 步骤 1 中的图像 3,3
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 RAM Replacement, RAM: 步骤 2 中的图像 1,2 Toshiba Satellite E45-B4200 RAM Replacement, RAM: 步骤 2 中的图像 2,2
    • Underneath the two plastic black flaps you will find the RAM sticks.
  3. Toshiba Satellite E45-B4200 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite E45-B4200 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite E45-B4200 RAM Replacement: 步骤 3 中的图像 3,3
    • To remove the RAM from the slot, pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Repeat the instructions for the other RAM slot.
结论
Raymond Makynen
于03/20/23注册
289 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 19
总计 250
