跳转到主内容
配件
没有特定配件。
  1. Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Gently pull out the battery.
    • Gently pull out the battery.
  3. Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Be sure to use ESD-safe tools, we recommend using the iFixit Pro Tech Toolkit
  4. Unplug the Hard Drive from the Motherboard. Unplug the Hard Drive from the Motherboard.
    • Unplug the Hard Drive from the Motherboard.
  5. Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out. Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
    • Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
  6. Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive. Remove the USB Port Circuit Board.
    • Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
    • Remove the USB Port Circuit Board.
  7. Gently remove the hard drive. Gently remove the hard drive.
    • Gently remove the hard drive.
结论
4等其他人完成本指南。
Delaney
于2016年10月11日注册
104 信誉积分
撰写一个指南
团队
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G4
3 名成员
创作了5篇指南
一条评论
By and large this and the B4200 guide are interchangeable. I followed both when reviving my B4100, as the pictures the respective authors show the components from different angle. Good stuff; thank you!
Kntai - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 23
总计 2,037
