跳转到主内容
Toshiba Satellite E45-B4100 Cooling Fan Replacement
你所需要的
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 6 中的图像 1,1
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the attachment from the Processor by gently rotating and lifting.
结论
另外一个人完成了本指南。
Brendan Sweeney
于10/11/16注册
182 声望
创作了2篇指南
团队
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 587
