当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Rotate the laptop so the back faces you.
Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
Use the plastic opening tool to pry the top panel up from the base of the computer.
Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
Disconnect ribbons, and slowly lift the top panel up, away from the base.
Locate the ribbon cable from the motherboard.
Using plastic removing tools, pop the ribbon base from the motherboard.
Locate the two plugs from the motherboard.
Using plastic opening tools, remove each plug from the motherboard.
Locate the ribbon cable partially hidden under the front panel.
Using plastic opening tools, pop out the ribbon cable from the motherboard.
Make sure that all wires have been disconnected before proceeding to avoid damaging components.
Slowly lift the top panel away from the base of the computer.
Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
Locate the black wire and white wire connected to the WiFi card.
Using a pair of tweezers remove the wires by lifting them straight up away from the board.
For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
Be careful not to pull the WiFi card straight up, as you might damage components on the motherboard.
Grip the sides of the WiFi card and lift it up partially.
Gently pull the WiFi card away from the black plastic base to remove.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
