简介
This guide is designed to help you quickly and safely replace the display screen when a problem arises. The display assembly includes the LCD, the front glass, and the display enclosure.
工具
配件
无需配件。
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen
Using your fingernail, remove each cover in order to expose the screw.
另外一个人完成了本指南。
