跳转到主内容
Toshiba Satellite Click 2 L35W-B3204 Battery Replacement
你所需要的
  1. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: 步骤 1 中的图像 1,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: 步骤 1 中的图像 2,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: 步骤 1 中的图像 3,3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 3 中的图像 3,3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 4 中的图像 1,1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 6 中的图像 1,1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
结论
Lexi Lannigan
于10/17/18注册
753 声望
创作了6篇指南
团队
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 UMass Dartmouth, Team S1-G4, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S1G4
6 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 822
