跳转到主内容
Toshiba Satellite CL15t-B1204X Power Connector Replacement
你所需要的
  1. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 3 中的图像 1,1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 4 中的图像 1,1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 5 中的图像 1,1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 步骤 7 中的图像 1,3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 步骤 7 中的图像 2,3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 步骤 7 中的图像 3,3
    • Disconnect the charging connector from the motherboard using the blue iFixIt opening tool by sliding it away from the connector.
  8. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: 步骤 8 中的图像 3,3
    • Pry the power connector upwards from the side of the laptop using the opening tool, then remove the part from the laptop.
结论
另外一个人完成了本指南。
Matthew Hook
于03/25/19注册
439 声望
创作了4篇指南
团队
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 288
