跳转到主内容
Toshiba Satellite CL15t-B1204X Hard Drive Replacement
你所需要的
  1. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Carefully unplug the cable near the USB on the left side.
  8. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Delicately pull on the hard drive and the case it's in to unplug it from the motherboard.
  9. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Peal the rubber casing around the hard drive off to completely remove the drive.
结论
4等其他人完成本指南。
4条评论
What kind of joke is this?! Spent an hour taking my toshiba apart and THERE IS NO DRIVE IN HERE!!!! WTF
Hammerjockey Radios - 回复
Do we change ssd hearddisk 240gb with same ram
Kamal Badiyani - 回复
I agree with Hammerjockey Radios, you guys should be more clear. there’s no drive on this model.
Ernesto Filho - 回复
I started to think the drive was missing b/c my model is just -1204, not the 1204X version. But then I looked again at the pics above. There is NO DRIVE in their pics either! Not until steps 7-8 where you can see they layed one in there. Steps 3,4,5&6... There Is NO drive so why would you be taking the battery out? Even if there WAS a drive in this model, unnecessary manipulation of a lithium battery is not a wise move.
NDR - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 40
总计 2,812
