跳转到主内容
Toshiba Satellite CL15t-B1204X Motherboard Replacement
你所需要的
  1. Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Unscrew the four 3mm screws with the PH1 screw head, on the corner of the heatsink.
  8. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the Heatsink from the board.
  9. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 9 中的图像 2,2
    • Unplug all 5 Ribbon cables connecting the motherboard.
  10. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 10 中的图像 2,2
    • Unscrew the seven 3mm screws with the PH1 screw head, which are surrounded by a red circle to make identification easier, from the motherboard.
  11. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 步骤 11 中的图像 1,1
    • Carefully pick up and remove the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 19
总计 662
