简介
Use this guide to replace a defective or shattered display in a Toshiba Satellite C875-S7304.
The display is a hardware component that presents visual information to you when using a computer. If you start to notice problems with the screen images or the glass screen has become cracked from an accidental drop, the display will need to be replaced.
Review the troubleshooting page before using this guide. Some issues may be resolved through display settings or a software update.
Take precaution when removing the display by disconnecting the laptop from any external power source and powering off your laptop completely before beginning the display replacement.
你所需要的
Power off and unplug the charger from your device.
Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
The two eject switches are located on the right and left side of the battery compartment.
Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
Open the laptop to show the display.
3等其他人完成本指南。
