跳转到主内容
Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C875-S7304 Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: 步骤 4 中的图像 1,1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out carefully using two hands.
结论
Emma King
于09/04/19注册
334 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 709
