跳转到主内容
Toshiba Satellite C855D-S5303 Fan Replacement
你所需要的
  1. Toshiba Satellite C855D-S5303 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 2 中的图像 2,2
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 3 中的图像 1,1
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 4 中的图像 2,2
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 5 中的图像 1,1
    • The battery can now be pulled out entirely. You are ready to replace it.
  6. Toshiba Satellite C855D-S5303 Fan Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
  7. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 7 中的图像 2,2
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be careful while removing the panel. Don't apply too much force when lifting as you may crack the plastic.
  8. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 8 中的图像 3,3
    • Locate the hard drive. It is in a metal casing as pictured.
    • To remove, grab the right side of the piece and slide leftwards.
    • Lift up and out.
  9. Toshiba Satellite C855D-S5303 Fan Replacement, Fan: 步骤 9 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement, Fan: 步骤 9 中的图像 2,2
    • Now that you have your battery and hard drive removed, it's time to begin unscrewing the back panel.
    • Taking a Phillip's head screwdriver, remove the two 7 mm (5 mm head) screws located around the spot where the hard drive once was.
  10. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 10 中的图像 2,2
    • There are nine 7 mm (5 mm head) screws located around the perimeter of the laptops back panel. Unscrew them all.
    • Be sure you put all the screws in a safe spot so you do not lose them.
  11. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 11 中的图像 1,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 11 中的图像 2,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 11 中的图像 3,3
    • Get a grip on one edge of the back panel that is now unscrewed and lift its entirety up and away from the device.
    • Be gentle when lifting the panel. Do not forcefully pull it off.
  12. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 12 中的图像 1,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 12 中的图像 2,3 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 12 中的图像 3,3
    • Upon locating your device's fan, look to see if it is dirty or clogged with dust before continuing with the removal process. That may be your only issue.
    • To remove the fan, unscrew the two 4 mm (3 mm head) screws that are around the fan.
  13. Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite C855D-S5303 Fan Replacement: 步骤 13 中的图像 2,2
    • Unplug the wire located to the left of the fan by pulling gently upwards.
    • Remember which way you pulled it out. You will want to replace the fan with the colors on the wire in the same orientation.
    • Now that the fan is unplugged, you can lift it up and out of the device.
结论
另外一个人完成了本指南。
Courtney Burns
于10/20/16注册
836 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,452
