简介
This guide will show you how to replace your disc drive. This repair requires only a small Phillips Head Screwdriver and your hands.
你所需要的
To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
即将完成!
结论
另外一个人完成了本指南。
