跳转到主内容
Toshiba Satellite C855D-S5303 Disc Drive Replacement
你所需要的
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 步骤 1 中的图像 1,3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 步骤 1 中的图像 2,3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 步骤 1 中的图像 3,3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: 步骤 3 中的图像 2,2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
结论
另外一个人完成了本指南。
Courtney Burns
于10/20/16注册
836 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 357
