跳转到主内容
Toshiba Satellite C855D-S5109 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C855D-S5109 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C855D-S5109 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 3 中的图像 3,3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Toshiba Satellite C855D-S5109 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using a Jimmy, slowly lift the keyboard up and away from the palm-rest. Slowly work around the edges, pushing the clips back, prying the keyboard up with minimal force.
    • Be sure to place the tool under the keyboard not the keys themselves!
    • Patience is key on this step; it might take a while, but don't force anything or you'll risk breaking a clip.
  5. Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite C855D-S5109 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Flip up the locking flap of the ZIF connector holding the keyboard cable on the motherboard.
    • Pull the keyboard ribbon cable out from the connector on the motherboard.
    • The ribbon should detach from the palm-rest not the underside of the keyboard.
    • Remove the keyboard from the laptop.
    • While replacing the keyboard, you will not need the Jimmy. Just gently press down around the edges of the new keyboard after plugging the ribbon cable in. You will hear it click back into place as the clips engage.
结论
另外一个人完成了本指南。
Brook Ostrander
于09/27/21注册
169 声望
创作了2篇指南
团队
Casper College, Team 1-3, Lareau Fall 2021 Casper College, Team 1-3, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 251
