跳转到主内容
Toshiba Satellite C855D-S5109 Cooling Fan Replacement
你所需要的
  1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: 步骤 4 中的图像 1,2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
  6. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: 步骤 6 中的图像 1,2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: 步骤 6 中的图像 2,2
    • Remove the twelve 6 mm screws from the back of the laptop with a Phillips #00 screwdriver.
    • There are 12 screws holding the back panel on the laptop. Two of the screws are located underneath the service panel.
  7. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 7 中的图像 3,3
    • Remove the DVD RW Drive by sliding it out.
    • Use a jimmy to pry open the back panel.
    • Pull the back panel of the laptop off, exposing the motherboard and other inside components.
  8. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: 步骤 8 中的图像 3,3
    • The cooling fan is in the bottom right corner of the laptop.
    • Unplug the small red and blue wire connecting the cooling fan to the motherboard.
    • Remove the two 3 mm screws securing the fan to the motherboard with a Phillips #00 screwdriver.
    • Remove the fan from the laptop.
结论
Brook Ostrander
于09/27/21注册
169 声望
创作了2篇指南
团队
Casper College, Team 1-3, Lareau Fall 2021 Casper College, Team 1-3, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 287
