跳转到主内容
Toshiba Satellite C855-S5115 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C855-S5115 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C855-S5115 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
结论
另外一个人完成了本指南。
2条评论
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - 回复
Do you have to do anything with the connector before removing?
William - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 2,529
