简介
This guide will show you how to replace your Toshiba's DVD tray when it is no longer working correctly.
你所需要的
Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
即将完成!
结论
