简介
Keeping your laptop cool is important to the speed and functionality of the device. This guide will show you how to replace your Toshiba's cooling fans.
你所需要的
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
即将完成!
结论
2等其他人完成本指南。
