跳转到主内容
Toshiba Satellite C855-S5115 Cooling Fan Replacement
你所需要的
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 7 中的图像 3,3
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 8 中的图像 1,1
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 9 中的图像 1,1
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 10 中的图像 1,1
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 11 中的图像 1,1
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 12 中的图像 1,1
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: 步骤 13 中的图像 1,1
    • Remove the CPU fan.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,494
