简介
For many laptops the WiFi card is under the HDD cover and replacing is very easy operation.
To change the WiFi half mini PCIe card on this laptop, you must to disassemble the bottom case.
你所需要的
视频概述
Switch-off the laptop and remove the battery.
Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
5等其他人完成本指南。
3条评论
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
