简介
Please remember to disconnect all power sources before beginning disassembly, including AC power cord and battery.
你所需要的
To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
Remove the 3mm screw located under the back access panel nearest the optical drive with a P1 driver.
即将完成!
结论
