跳转到主内容
Toshiba Satellite C75D-A7370 Hard-Drive Replacement
你所需要的
  1. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 2 中的图像 2,2
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 3 中的图像 3,3
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 步骤 4 中的图像 1,3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 步骤 4 中的图像 2,3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 步骤 4 中的图像 3,3
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
  5. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Hard-Drive: 步骤 5 中的图像 1,1
    • Locate the hard-drive.
  6. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the two 7 mm screws holding the hard-drive in place with a P1 driver
  7. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 步骤 7 中的图像 2,2
    • Then using the tab located on top of the hard-drive pull up towards you and then pull to the left to disconnect the hard-drive. Now you are ready to replace your hard-drive.
结论
Basim Ismail
于02/02/17注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 2,018
