跳转到主内容
Toshiba Satellite C675-S7106 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 2 中的图像 2,2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C675-S7106 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
结论
Dinis Valcorba
于03/26/19注册
292 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 的会员
UMASSD-SIMCOCK-S19S1G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 461
