跳转到主内容
Toshiba Satellite C675-S7106 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C675-S7106 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite C675-S7106 Hard Drive Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite C675-S7106 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
结论
另外一个人完成了本指南。
Dinis Valcorba
于03/26/19注册
292 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 的会员
UMASSD-SIMCOCK-S19S1G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 379
