跳转到主内容
Toshiba Satellite C675-S7106 CMOS Battery Replacement
你所需要的
  1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 CMOS Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C675-S7106 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 1,2 Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 2,2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0-head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 CMOS Battery Replacement: 步骤 4 中的图像 1,1
    • Using a thin pry tool, gently remove the battery from its socket.
结论
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 的会员
UMASSD-SIMCOCK-S19S1G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 282
