跳转到主内容
Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
你所需要的
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 步骤 1 中的图像 1,2 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 步骤 1 中的图像 2,2
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: 步骤 2 中的图像 1,1
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: 步骤 3 中的图像 1,1
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
结论
3等其他人完成本指南。
Shelby Kunz
于04/19/13注册
69 声望
创作了5篇指南
团队
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G20
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 9
总计 3,020
