跳转到主内容
Toshiba Satellite C655D-S5084 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
结论
4等其他人完成本指南。
Shelby Kunz
于04/19/13注册
69 声望
创作了5篇指南
团队
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G20
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 3,408
