跳转到主内容
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
你所需要的
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: 步骤 1 中的图像 1,1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: 步骤 2 中的图像 1,1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
结论
4等其他人完成本指南。
Shelby Kunz
于04/19/13注册
69 声望
创作了5篇指南
团队
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G20
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 4,928
