简介
If your device has a short battery life, or does not hold a charge at all, you may need to replace your battery. This guide will help you remove your old, worn battery, and replace it with a new, fresh battery in your Toshiba Satellite C655D-S5084.
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
即将完成!
结论
另外一个人完成了本指南。
