跳转到主内容
Toshiba Satellite C655-S5142 RAM Replacement
你所需要的
  1. Toshiba Satellite C655-S5142 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Toshiba Satellite C655-S5142 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Ensure that your laptop is turned off and the battery has been removed
    • Flip over your laptop where the battery side is closest to you.
  2. Toshiba Satellite C655-S5142 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C655-S5142 RAM Replacement: 步骤 2 中的图像 2,2
    • Unscrew the singlular screw in plate with a Phillips #1 screwdriver.
    • The screw does not come all the way out of the plastic plating, instead there is a protector that keeps it in place for you even when fully unscrewed.
  3. Toshiba Satellite C655-S5142 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite C655-S5142 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite C655-S5142 RAM Replacement: 步骤 3 中的图像 3,3
    • To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
    • Once pushed outwards, the first RAM stick will pop up at an angle
    • After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
结论
另外一个人完成了本指南。
Hunter Gonsalves
于03/24/19注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 209
