跳转到主内容
Toshiba Satellite C655-S5142 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Unplug your computer, and make sure that it is shut off before starting
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C655-S5142 Keyboard Replacement: 步骤 4 中的图像 2,2
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
结论
另外一个人完成了本指南。
Alex Kozlowski
于03/21/19注册
244 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 334
