跳转到主内容
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
结论
zeena qiryaqoz
于01/17/17注册
301 声望
创作了3篇指南
团队
一条评论
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 705
