跳转到主内容
Toshiba Satellite C55Dt-A5306 Disc Drive Replacement
你所需要的
  1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: 步骤 2 中的图像 1,1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: 步骤 4 中的图像 1,1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: 步骤 6 中的图像 2,2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: 步骤 7 中的图像 1,2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: 步骤 7 中的图像 2,2
    • Slide the disc drive to the left. It should come off with ease.
结论
zeena qiryaqoz
于01/17/17注册
301 声望
创作了3篇指南
团队
一条评论
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
ed_l_grey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 421
