跳转到主内容
Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement
你所需要的
  1. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  2. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 2 中的图像 1,1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  3. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 4 中的图像 2,2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  5. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, DC Power Jack: 步骤 5 中的图像 1,2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, DC Power Jack: 步骤 5 中的图像 2,2
    • Remove the DC power jack from its plastic retaining piece, just inside of the charger inlet.
  6. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: 步骤 6 中的图像 2,2
    • Use the nylon spudger to remove the connecting wires from the motherboard. Insert the spudger between the terminal plastic piece of the wire and its retaining clip on the mother board. The wire should release without much force.
结论
一条评论
I got a power jack from seller dcincable.com, it's exactly the same as your images show, but I could not find a service manual, it's great to have your help, thank you so much.
Tom - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 793
