跳转到主内容
Toshiba Satellite C55Dt-A5306 Fan Replacement
你所需要的
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 2 中的图像 1,1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 4 中的图像 1,1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 6 中的图像 2,2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 9 中的图像 1,1
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite C55Dt-A5306  Fan Replacement: 步骤 10 中的图像 2,2
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
结论
Nahrain Putris
于01/17/17注册
329 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 412
