跳转到主内容
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
你所需要的
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 步骤 1 中的图像 1,3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 步骤 1 中的图像 2,3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 步骤 1 中的图像 3,3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 3 中的图像 2,2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 6 中的图像 1,1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 步骤 7 中的图像 2,2
    • Pull the fan and heat sink away from the motherboard.
结论
Laura Tamayo
于02/14/19注册
678 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 337
