跳转到主内容
Toshiba Satellite C55D-B5310 Touchpad Replacement
你所需要的
  1. Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 2 中的图像 3,3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
  3. Toshiba Satellite C55D-B5310 Touchpad Replacement, CD/DVD Drive: 步骤 19 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  4. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 20 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 20 中的图像 2,2
    • Slide the CD/DVD Drive out of the laptop.
  5. Toshiba Satellite C55D-B5310 Touchpad Replacement, Touchpad: 步骤 21 中的图像 1,1
    • Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  6. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 22 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 22 中的图像 2,2
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  7. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 23 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 23 中的图像 2,2
    • Release the clamps holding the white ribbon between the touchpad component and the motherboard.
    • Slide the ribbon from the motherboard connection socket.
  8. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 24 中的图像 1,1
    • Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
  9. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 25 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 25 中的图像 2,2
    • Release the two clamps connecting the blue ribbon to the external touchpad.
    • Lift the black clasp holding the blue ribbon in place.
  10. Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 26 中的图像 1,2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 步骤 26 中的图像 2,2
    • Slide the blue ribbon from the external touchpad holding socket.
    • Lift the touchpad module from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 892
