简介
This guide will show you how to remove the speakers from a Toshiba Satellite C55D-B5206 laptop. This process is relatively simple, but it has a lot of steps and will require some time.
你所需要的
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
Remove all pieces of yellow polyimide tape that covers the connectors and cables on the motherboard.
即将完成!
结论
