跳转到主内容
Toshiba Satellite C55D-A5304 RAM Replacement
你所需要的
  1. Toshiba Satellite C55D-A5304 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Toshiba Satellite C55D-A5304 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Turn off your laptop and make sure that it is not connected to any power source.
    • Put the laptop upside down so the back panel is facing you.
    • Remove the battery from the back of the computer.
  2. Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 2 中的图像 3,3
    • Find the backplate on the back of the laptop and unscrew the single, 5mm screw with a Philip Head Screwdriver.
    • Using your finger, go under the ledge of the back plate and take it off to expose the RAM.
  3. Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 3 中的图像 3,3
    • Once the RAM is exposed, use both hands to unlock the RAM and pull apart the metal pieces holding them in.
    • The card will pop out at an angle and you will need to carefully pull it out. If not using even pressure to remove the card, the RAM will be locked into the slot.
  4. Toshiba Satellite C55D-A5304 RAM Replacement: 步骤 4 中的图像 1,1
    • You can insert your new RAM card into the slot very carefully. It will insert at an angle.
    • You can then push down on the flat face of the card and it will lock into place.
结论
AbbyThorng
于03/15/23注册
217 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-1, Petersen Spring 2023 UMass Dartmouth, Team 3-1, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 120
