跳转到主内容
Toshiba Satellite C55D-A5304 Fan Replacement
你所需要的
  1. Toshiba Satellite C55D-A5304 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the laptop is disconnected from all power sources and turned off.
    • Start with computer upside down with battery slot facing up.
  2. Toshiba Satellite C55D-A5304 Fan Replacement: 步骤 2 中的图像 1,1
    • Use the buttons of the sides of the battery to slide inwards and release the battery.
  3. Toshiba Satellite C55D-A5304 Fan Replacement: 步骤 3 中的图像 1,1
    • Take the battery out.
  4. Toshiba Satellite C55D-A5304 Fan Replacement, Fan: 步骤 4 中的图像 1,1
    • Open the back of the laptop using a pry tool.
  5. Toshiba Satellite C55D-A5304 Fan Replacement: 步骤 5 中的图像 1,1
    • Once you see the fan, to make the cleaning process more convenient use a screwdriver to unscrew the 4mm screws on the fan.
    • To the immediate right of the fan the wiring harness is located. Disconnect this also to remove the fan.
  6. Toshiba Satellite C55D-A5304 Fan Replacement: 步骤 6 中的图像 1,1
    • Use a microfiber cloth and/or compressed air to clear any dust or clogging.
结论
另外一个人完成了本指南。
Emily Verre
于03/13/23注册
211 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-1, Petersen Spring 2023 UMass Dartmouth, Team 3-1, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 81
