跳转到主内容
Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement
你所需要的
  1. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 步骤 6 中的图像 1,3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 步骤 6 中的图像 2,3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 步骤 6 中的图像 3,3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 7 中的图像 1,2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 7 中的图像 2,2
    • Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
  8. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 步骤 8 中的图像 2,2
    • The card will pop up; gently pull the card out of the port.
    • Unplug the wireless antenna cables attached to the card.
    • Remember how the cables were connected to assure you do not cross the Bluetooth and wireless connections by accident.
结论
Ryan Smith
于10/25/19注册
187 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 40
总计 927
