跳转到主内容
Toshiba Satellite C55D-A5108 RAM Stick Replacement
你所需要的
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 步骤 2 中的图像 1,1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 步骤 3 中的图像 1,1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 步骤 5 中的图像 1,1
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 步骤 6 中的图像 1,1
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
结论
Geoffrey Souza
于10/25/19注册
327 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 250
