跳转到主内容
Toshiba Satellite C55D-A5108 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55D-A5108 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
结论
Michael Medeiros
于10/25/19注册
150 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 245
