跳转到主内容
Toshiba Satellite C55D-A5108 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108  Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108  Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108  Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
结论
另外一个人完成了本指南。
Geoffrey Souza
于10/25/19注册
327 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 265
