跳转到主内容
Toshiba Satellite C55-a5310 Keyboard Replacement
你所需要的
  1. Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,2 Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  4. Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  5. Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to remove the keyboard from the laptop.
  6. Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite C55-a5310 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
结论
3等其他人完成本指南。
Kari Rodgers
于02/08/18注册
482 声望
创作了4篇指南
团队
2条评论
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - 回复
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
Jeff Breuer -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 2,252
