跳转到主内容
Toshiba Satellite C55-C5268 LAN Card Replacement
你所需要的
  1. Toshiba Satellite C55-C5268 LAN Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 LAN Card Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 5 中的图像 2,2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 步骤 6 中的图像 1,2 Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 步骤 6 中的图像 2,2
    • Gently remove the ribbon cable from the clip its held in. Peel back the tape holding it in and pull the cable straight out. It is not necessary to unclip the holder.
    • The correct ribbon has a blue ends labeled with LAN.
  7. Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 7 中的图像 1,1
    • Remove the two 5.0 mm screws, using a Phillips #1 screwdriver, once the cable is out of the way.
  8. Toshiba Satellite C55-C5268 LAN Card Replacement: 步骤 8 中的图像 1,1
    • Lift the card out of the laptop to replace it.
结论
Ben Rounseville
于10/21/16注册
471 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G1
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,336
