跳转到主内容
简介
This guide will show you how to properly remove and replace the Heat Sinks.
配件
没有特定配件。
  1. Toshiba Satellite C55-C5268 Heat Sink Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Heat Sink Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-C5268 Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: 步骤 6 中的图像 1,2 Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: 步骤 6 中的图像 2,2
    • Unscrew the four 5.0 mm screws holding the heat sink in place using #1 Phillips screwdriver.
    • The 5.0 mm screws can unscrew from the laptop, but stay attached to the heat sink.
    • One of the screws is underneath a ribbon. Be sure to gently move the ribbon out of the way first.
    • Be sure to screw the replacement heat sink in the correct way.
结论
Ben Rounseville
于2016年10月21日注册
468 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G1
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 505
