跳转到主内容
Toshiba Satellite C55-C5268 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite C55-C5268 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Hard Drive Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Pull the two rubber stops upward to move them out of the way and free the hard drive.
  7. Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Slide the hard drive to the right towards the stops. This disconnects it from the motherboard.
    • This will require some force to slide the hard drive.
  8. Toshiba Satellite C55-C5268 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • The hard drive can be lifted out for replacement.
结论
8等其他人完成本指南。
Greg Smith
于10/24/16注册
347 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G1
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 29
总计 13,742
